Hose temper tantrum
Had to clean a three story house yesterday. 43 stairs and snow white urine soaked carpet. It was a real pain in the rear, and back. But I pulled through.
Clear your hose and take off what you don't need. Makes life a lot easier. I'd rather walk up and down the stairs a few times rather than deal with that snake pit.
I lay the wand down and pull it back it back to the van to stage it. That much hose you should be due for a break.
Reactions: Dolly Llama
sassyotto
Paul
I know you had a long day, but you gotta be more efficient. Like the above stated, take off what you dont need (better heat and suction too) Plus less of a trip hazard for both you and your customer.
Should be a picture of what not to do.
Reactions: Sierra Clean Care
Wasn’t going to happen on that job. This was a three story house with large runs between rooms.
Hows your back? You should consider getting a weight lifting belt for back support. I use one.
It’s getting better. Today the healing made very good progress. I’m still a little sore and weak but I’m almost back to normal. I’ve turned down three stretching jobs since hurting myself. I think I’m done trying to be the hero all the time. Cleaning carpets is what I enjoy. Not the repairs and stretching. I’m busy enough to not have to do that stuff.
That is [HASH=13]#cheating[/HASH] in residential, but if you can get by with it, hack it out!!
Jeff T
Have no problem with it as long as the paying customers are not.................around.
