Hoss early review
Its early but I gave it a good workout today. First impression it is faster and drier than the rotovac.
They both clean the same as far as I could tell. The hoss didn't pop any seams even some that were weak. The rotovac would of eaten them. It will be harder to train someone on. I like the site tube but who wouldn't. I wish they would of put an adjustable vacuum port like on the zipper. It may be perfectly placed but I'd like to try others. The bracket holding the vacuum should be slightly wider so you can snake the solution tube through. I ran it without the reducer and with the .52. Joe suggested to change the angle of the spray bar. Definitely going to do that but forgot. It did leave the carpet dry but not as dry as the zipper. The t-Rex left it drier and I thought tied the zipper. Changing the spray bar angle may fix that. It's well built and the strap is a winner. It won't get used much but when necessary I'll be glad to have it.
Gene
