We have had this happen twice in the past from
RX20's (our
Rx20's all had
glides at the time) and I recently got a call from another company with the same issue. If you were to inspect with a magnifying glass the tips of the loop pile you could see where they were bent over slightly in different directions. I believe from time to time a truck mount will spike with too much heat and cause the carpet to heat set in different directions, because of the close proximity of the jets to the carpet and shroud holding the heat in. We were unable to correct the 2 problems we caused, one of them the client lived with it, the other client had us replace the carpet. At the time we tried using the hottest truckmount we could find and run the wand directly in front of a pile lifter, the problem was we couldn't get a truck over 230 degrees, plus we had a 200' run of solution line.
The good news is we now have a vapor steamer (270 degrees at the wand, so to speak) I rigged the vapor steamer up to a brush pro for the other company and showed them him how to drive super heated steam into the pile while immediately following up with the brush pro. He said he got rid of the problem. You can rent a vapor steamer for about $100 form most rental shops if you don't have one, or call some local carpet cleaners and borrow one like my friend did. If you need a picture of how I rigged it up let me know, and I will rig it back up and show you.
Good luck.
