But the carpet feels dryer after a single pass with the steel
glides.
you can't go by "feel"
case in point, I "thought" hole glides made a world of difference
I cleaned two identical area rugs, one with hole, one w/slot...same wand (a Ti notched to facilitate quick glide change)
The "feel" doing side by sides was dramatic immediately after .
I set the rugs aside and finished cleaning the living rm
when i positioned the area rugs where they go, i could feel NO difference in the two.
immediate "feel" difference right after cleaning, 15-20 min later, no difference
It got me doing side by side tests at home where I could monitor to complete dry
There wasn't/isn't a dimes worth of difference in complete dry times .
carpets were heavy cut pile nylon, short loop olie and heavy cut pile poly
same rooms, same day, same wand, same pre-spray...same everything ..same dry times
