How do I get this busted piece of brass out?........
Blue Monarch
Dirk Wingrove
I don't even know what terminology to use in order to search.....
Wtf do I use that is safe to fix this mess? Machine is down until fixed....the luck continues.
Large Screw driver wedged in is one way, but they do make large "easy Outs" that would fit. Would start with that if you can get to the hardware store.
Have had it happen a few times on things.
Easy out is like a reverse looking drill bit with knurls on it. Let me know if you need a picture and I could try and find one in my shop quick.
Blue Monarch
Dirk Wingrove
Thanks Mark, I'm on it! The real bugger will probably be getting the new part before a big job on Monday.
Easyout works well. Any hardware store should have it. I think Harbor freight even sells them. As Mark says in digs in and makes removal a breeze.
Dirk is that the solution outlet manifold? What broke off?
Lots of belt suppliers sell brass for the hoses they sell. Dultmeirs (Omaha) and Windtrax (KC) are both probably 1-day ups to you.
Blue Monarch
Dirk Wingrove
It's a manifold...no Idea what it's called. lol.
I had to remove the damn brass fittings cuz I dropped an orifice into the manifold when I was descaling.
http://www.toolprice.com/product/1225D/Srew-Extractor--Bolt--Stud-Extractor--Bolt-Removal.html
One place I found online for a pic of easy outs.
I bet if you go to ACE they will have the correct brass pieces you can make something work. I have had to do the same. Might take a few more pieces to make what you need, but you should be able to be up and running with in no time
Mark
Sorry....was going to post pics faster, but 2 calls rolled in at the same time for carpet cleaning.....on a Saturday calling to schedule....thank goodness!
GCCLee
If no easy out around, use the screw driver trick. Might need to tap it with a hammer so it will bite good
Reactions: Mark Saiger
Can you post a pic of the broken part so we know what you are trying to simulate? I might be able to tell you what to find at the hardware store to make it work.
Mark
Blue Monarch
Dirk Wingrove
Got the part at true value. Off to harbor freight soon to get the screw extractor. Thanks for the tips
Royal Man
That brass always breaks off at the thread. I'm surprised you haven't had this happen several times by now. I have new brass break off just tightening them up for the first time. I keep an easy out on the truck and a few brass fitting for on the job repairs.
Russ T.
Russ Terhaar
The smaller hardware stores are great. They will usually have someone who begins to own your problem when you walk in the door. Maybe it's because I'm in Iowa but I'd go into my tiny small town hardware store and I bet it would be fixed when I walk out. Your probably in a similar spot Dirk? Glad to hear your working it out.
The Clean Machine
Connor
Connor
Get a Rectorseal brand Golden Grip internal pipe wrench. Works fo' sho' !
I'm a jerk.
They're about 25- 50 bucks at a plumbing supply shop.
dgardner
Be careful if you use the easy-outs like Mark posted. As you turn them (to the left), they wedge themselves further and further into the broken piece, expanding it. If the piece is stubborn and doesn't break loose, you can turn it in so far it expands and splits the manifold (ask me how I know this). Penetrating oil is your friend.....
1/2" to 3/4" blunt nose brass extractor...about $7.00
not a screw extractor..too small
GCCLee
Find a Flat Head Screw Driver as close to the dame size as the hole.
Screw buying a buncha expensive tools! It's Soft Brass
If your lucky you can get away wit just crammin it in the hole an turning it out.
A steel bolt, use an easy out!
Quit being a weenie an fix it already : $
glenboy
GLEN
I keep a set of ez outs on board....anything else is askin for trouble
Sent from my SAMSUNG-SM-N900A using Tapatalk
Reactions: Lee Stockwell
Connor
Connor
Yeah, sure, try your luck, lol.
Screw buying a bunch of expensive equipment ,too. Get rid if that TM and buy an OP.
I'm a jerk.
Reactions: jcooper and GCCLee
GCCLee
I'm a jerk.
He would stick a screw driver in der it might save him a buncha hooplaa
Jus sayin
Btw, ya got me pretty good Jerk!
Reactions: Connor
Connor
Connor
Jus sayin
A true statement, it might. I've never been that lucky. I've been licky more times than I can count, but lucky, notsomuch.
I'm a jerk.
Reactions: GCCLee
Because brass is soft........the best extractor for the job is this style......
just tap it in there and turn.....screw drivers are not a good idea...
