how do I get this pulley off.
San Francisco, CA.
This is the pulley to motor for my hose reel on my 2004 Vortex.
I removed the pin and wedge but still have difficulty removing the pulley. I'm trying a gear puller but still seams difficult. Even used WD40.
What am I missing?
ronbeatty
Altoona,PA
Ron Beatty
Spray it liberally with PB Blaster, let it sit for 20 minuets, lightly heat it with torch, should pop off.
Get the gear puller real tight and smack the end you put the wrench on. It should pop loose after a couple tries.
Heart of Dixie
Oil of wintergreen is the best penetrant on Earth. Let it soak in overnight. Then pull and warm the pulley. It will expand slightly on the shaft and break loose. Polish and oil the surfaces lightly before putting it back on.
La La Land
Take and screw a bolt of the proper size and thread and screw it into the center hole and it will push the pulley right off
Shane T
Waukesha, WI
Shane Tiegs
If there are threads in the center hole do as Bawb suggests. You may need a pair of large slip joint pliers to hold the pulley while turning the bolt. WD-40 is not a very good penetrant.
Hawaii
San Francisco, CA.
Your puller is pretty light/bendy - a stouter puller would probably help.
http://www.amazon.com/Sunex-3908-Capacity-Reversible-Puller/dp/B000ROFZ2M
As far as penetrants, everyone has their fave - mine is Kroil from Kano Labs - the stuff is magic....
http://www.kanolabs.com/penLub.html
Yeah That's The pulley I wanted to get but wasn't available at store near me. I'll look for it at other places tomorrow, cuz I think I'll need it.
I got PB Blaster-- May God!! I'm Surprised that's stuff is legal!! I washed away the rust like nothing I've ever seen!
Ken692
Boston
Kenny
Tie it to a fire hydrant and drive around the block a few times
Works every time !
