Cleaning stone really isn't too scary. Don't use just any alkaline as some stone is alkaline sensitive as well as acid sensitive. Use an alkaline cleaner made for use on stone, especially polished stone. Do not use a hard wand, glided or other on polished stone. You can scratch it. Use a tool with a brush ring or other soft surface and make sure there is no debris stuck in it, mainly on polished surfaces.
Mostly you will find the stone is dirty from cleaner residue and cleans rather easily. Keep your heat lower, 180*-210*, and psi around 800. Be even more careful with most limestones as you can leave swirl marks with a turbo type tool with too much psi.
Not all stone is porous or needs to be sealed, especially polished stone, some do though. Test. Pour a small puddle of water, let it sit for 15 min and wipe it up. If it is darker where the water was, it can be sealed. If not, leave it alone!
I like TOG Stone Prep for cleaning.
Good luck.
