Warren Wallace
- Joined
- Oct 4, 2007
- Messages
- 839
You clean urine spots they look great but, with a black light you
can still see them,please explain why is this..
sweendogg said:When Urine/bodily fluids are emitted they contain certain proteins that will fluoresce because of the particular molecular structure. These proteins and the body fluid itself is acidic in nature and heated to body temperature. This lowers the surface tension of the body fluid making it easy to penetrate surfaces such as carpet, pad, wood, fabrics ext. The Proteins(acidic in nature.. ie amino acids) end up saturating any open dye sites in the carpet or saturating hardwood/floors much like a Kool Aid drink does. As the urea or extra products are digested by bacteria, the proteins remain and often become bonded with the fibers in such a way that they often will not remove. This is usually true of Nylon and polyester. Olefin and Smartstrand fibers usually will not hold onto these proteins nearly as well. wool can wash out depending on the dyes and chemical treatments, while some wools will not.
I was taught it was due to mineral deposits in the protein, magnesium in particular, is this correct or am I just splitting hairs here?
