daniel@procarpet
I cleaned a filthy nasty blue nylon carpet this evening. It was just one room and open areas. I had to pick up a ton of stuff and move a few small things. I decided to use the RX-20 full slots unglided at 600 psi. I only had to run 60' of hose. It took me over 30 minutes to clean with the RX one small room or about 200 sq ft of carpet. I used a ton of water for such a small area. The water going through the sight tube was choclate brown. I was moving it so slow but no dry strokes. It cleaned better than anything I have ever seen. I vacuumed the carpet for about 30 minutes before cleaning. My plan was to go back with my glided wand and dry stroke. I felt the carpet in several areas and it was not even damp so there was no need to even use the wand. It was really dry. I couldn't believe it.
I did have an issue with a couple seams coming apart and that freaked me out. That wouldn't have happened with the glides but the rx just will not clean as deep on a pile carpet with them on. I will have to be careful.
It takes forever to use the tool and I think the better dry times come from moving it really slow, but it is worth it on certain jobs. There is no way I could have got this carpet clean with my wand spray and suck. The traffic lanes would have came back in a week.
