how long would it take you
rcl1006
i had a condo on the 3rd and 4th floor. there were 3 full bedrooms a 2nd living room 2 walk in closets, and a sitting area. 2 sets of stairs with 2 landings going down to the 3rd floorwith 8 steps on each section. carpet sq footage was a little over 1000 sq ft plus the steps.
i used my tm sent a set of hoses down from the 4th floor etc.
it took me about an hour to set everything up
carpets were`nt trashed they were do for a cleaning.
i vac`d it , presprayed and agatiated it, extracted it, gave it a fiber rinse,did 2 spot removels then raked it
job came out great i think i took to long,i did it by myself.
how long will it take you, and what would you charge for it
thanks rob
Ken Snow
Bingham Farms MI
Ken Snow
In the hour you took setting up most of my 2 man crews would have been almost finished. I think it did take too long.
rcl1006
like i said i was bymyself made a few trips up and down to setup. did the walk thru with the customer. how long would it take just 1 tech start to finish
rcl1006
ok so if it`s taking 45 min to set up and at least 30 min to break down. your techs doing that in 45 min or so?
Scott Rogers
with that setup and pre-vacuuming I would say 3.5-4 hours but there are alot a variables that would affect that. how much furniture was there to move, how cut up was the job. how many passes were required. etc.
I don't think Ken's crews vac, do they??
I don't think they pre-spray "average" jobs either
single man in the scenario you described
(we actually have a complex that sounds similar in set up)
appx 15 minutes to set up.
based on 1000sf of carpet actually cleaned;
20 to 30 minutes to vac 1000sf.
Maybe longer if it needs "Wernerized"
an hour to an hour and half to pre-spray and clean "right"
12 minutes tear down
the wild card here is if empty, how much furniture moving or if the custy is home.
The appx times I gave would be for no one home and no (or minimal) furniture moved
1000sf would + 16stairs = 650+88=738
would take me about the same time to set up, most likely about 5hrs total. When you're by yourself its a whole lot different than with 2 guys. Esp if you're taking your time to not hit anything or mess up the landscaping. The time and care I take is part of the sale, comparing it to the guys that would be in and out in 1-2hrs incl set up. If its a move out, its usually a price deal and I'll refer it to the 1-2 hr guys.
Ken's guys would have ran up the stairs with pressure, vac hoses and wand in hand.
Tossed them over the rail to the helper down below and in three minutes would have been wandulsifying away.
Helper boy would then come up and help pull hoses and post spot.
and possibly groom.
if they didn't leave the Grandi at the last job
six years ago....
dayum...5 hours to clean 1000 sf.... :shock:
you'd think they'd get sick of seeing your anal retentive mug.... :p
joeynbgky
Bowling Green
Joey
your time is not bad, but if my tech took that long id be driving over there helping. A portable would have been nice for that job i am sure.
I don't see how a porty would of saved any time, Joey.
he'd still have to bring up all the same stuff..ie, wand, hoses, sprayer, spotting kit, etc... PLUS a 100 pound porty
climbing steps can be a PITA, be realistically you're only adding another 30 to 40 ft of hose to the job
joey895
Florida
Joey J.
I have one that sounds very similar that I've cleaned a couple of times. It takes me about 3 hours by myself set up and tear down included.
I don't groom though. gasp.
Benton KY USA
Elevator is great for the TM too. Ride up with most everything in one trip. 4th floor is only 30' of extra vertical. I have my solution lines on portable spools. Carry 50' of vac hose looped over my shoulder, wand, HF, and solution spool. Hook up HF to far point and unwind back toward the truck, usually down the center of a staircase. Go back down, hook up hoses and start TM. Get spotter bag and second section of vac hose and make the connection. Max 20 minutes.
650sf/hr when the machine starts. Haul!!
Wrapup 20 minutes max, even for me (58 years and counting).
joeynbgky
Bowling Green
Joey
lee, do you still clean carpets? or do you sit in the office and watch all the judge shows all day? which ones your favorite mathis? judy?
carpetcleaner
Gilbert, AZ
Rob Litwin
I pass on the multi floor condo work. That is too much like work. I like cleaning houses where I don't need more than 150ft of hose.
I just had to clean a condo yesterday. It was only on the 2nd floor, but the only access was from a dirt lot next to the building with the hoses up through the balcony. It was a little over 700sf of carpet and no stairs. It took about 1 1/2 hours from driving up to pulling away. It was vacant. I did vacuum before cleaning.
No, 5hrs total
Arrive, measure/quote/setup/clean/tear down/finalize with client
Its a guesstimate. I don't mind taking my time. I'm in no rush. Get moving a lot of furniture, plus doing stairs, adds some time.
They see me doing an awesome job on their carpet, most times they leave me a cheque/cc# and take off, I call them when I'm done or am able to lock up on the way out.
rcl1006
thanks for the responces. it took me 5 hours. there was a elavator . i did`nt make it in one trip more like 3.
brought up vac, sebo ,blower,wand, stair wand, 100` and 50 ` of hoses, wall guards, towes, bucket.
i thought it took me to long.
