how many GPM flow???
I have 1.5 jets on our Ti
1.5 x 6 = 9
I just bucket tested the wand
I didn't measure with absolute precision, but close enough to be with-in a few/several ounces
Timed w/stopwatch 60 seconds.
100ft Parflex
500ps ATM
(drops to 400 w/wand keyed)
I measured 7.6869 liters :mrgreen:
260oz
that's over 2 GPM
I though 9 flow was less than 2gpm
Shawn Forsythe
500 psi: 3.25 gpm
300 psi: 2.47 gpm
You also have to account for a pressure drop due to frictional loss (below the 400 psi) at the end of the hose (at the jet body).
It normally is....your jets must be worn...or your pressure is a bit higher than the gauge indicates.
I would put 09 flow at about 1.6-1.7gpm at the pressure you listed.
