How much does a Judson TNT weigh?
woodsey
I guess mine weighs about500 lbs dry without the LG#4 or the propane tank.
more than I weigh on a bad day
More than I can lift on a good day
I think my CanAm weighed around 700lbs. You should be able to work out an approximation, blower, pump, engine, guages, the biggest variable will be the tank
seattle
These guys would know.
Factory Direct Outlets
Greenville, SC
864-233-6442
Sarasota, FL
941-724-0701
Shelbyville TN
I had one many years ago. Don't know if the weight is anywhere near the same now. It was 556 pounds for the main unit. This did not include the waste tank, hose reels, hoses, etc.
Fort Worth , Texas
I thought Judson main unit has always been the waste tank?
Did you mean the fresh tank?
Shelbyville TN
You are correct, Waste tank was built into the same frame. Details get fuzzy after 25+ Years.
Judson company would be the ones to have the exact answer for current units.
