Jim Martin said:
[quote="Mikey P":83zfn8fs][quote="Jim Martin":83zfn8fs]most houses are a huge waste of time to duel wand.....
dual wanding shines more in large commercial jobs............
I love it when Jim is wrong.
It's not often but he is dead wrong here.[/quote:83zfn8fs]
pull up to home...one guy grabs vacuum and starts at the far end of the house....vacuuming and putting what ever needs moved on sliders......
the other guys starts setting truck up.....pulling in hoses..corner guards..... etc.........spray and clean first room that has been vacuumed..
the guy with the vacuum should be done.....he can grab the second solution line..( which was brought in and laid in place during the set up ) and start pre-spraying/scrubbing the next area....
from here it is just a game of leap frog...guy with wand is done in room...he moves to next area that has dwelled and is ready to clean....guy that is pre-spraying starts grooming area the guy with the wand just finished..tabbing anything that had to be moved.......stacking or re-setting corner guards....
get this well orchestrated and worked into your system to fit your needs.....it will be rare you pull in 2 vacuum lines.....
for me this was 10 times more efficient and was the better way to go on 95% of the homes we have down here.....[/quote:83zfn8fs]
IF I ever hired a helperboy we would dual wand. But then I would need a dual wand TM. Maybe
Sapphire Scientific's 870SS. The last few years I had a helper was in the 80's and we put two Vac11s into the back of the Pinto or Vega wagons (whichever was running) and would set up like Jim said; start up the other steam cleaner after all the other details were attended to. We would REALLY make time running two machines at once.
