Aaabrightfloor
I want to play around with different jets on my sx-12
how do I read a jet?
my SX_12 has Veejet 1/8 ss MEG 0502
thanks
thanks
thanks
where you can make changes usually depends on the machine your running. If your running a big machine with high vacuum you can go with a bigger net (more water) because you can recover it. Also you will see a heat drop on smaller heat exchange machines with higher flow as the water is moving faster through the exchanger not allowing it time to heat up. I'm sure more will reply but that's a start call Monday of you want to talk more.I want to play around with different jets on my sx-12
thanks
Like John said there is a sweet spot for all different machines.. For me .09 flow(.015 across a 6 jet to wand) is the best when cleaning heavily soil carpet. For lightly soiled I run .06 flow (.01 a cross a 6 jet ti wand) and I can save some water this way also.
I really whouldn't mess with any tile cleaning tools jets, reason being with smaller jets you will get a sharper more penetrating spray.. JMO I really don't clean all that much tile..
