Any ideas?. They've been dipped in acidic water for a few hours and no luck. I put the nuts slightly in and bang away but no luck yet. This is an rx that I'm trying to remove the original skids to replace with glides.
It is a penetrating lubricant my Grand pappy used on the farm. You should be able to get it at hardware, automotive, or your local Wal-mart store. The farm hands called it monkey piss. I don't know why that was the term but it will soften about any connection. "Liquid wrench" is a good one as well.
I've been beating the crap out of them just as you suggest the whole day, no luck. There's a few soaking in acid and sprayed one with wd40. Didn't have time to look for something similiar to what Rex suggested.
Thanks, finally got em out. Acid bath, banging, citrus, banging and more banging, propane torch , wd40, banging
Thing is inside of the threads is hard due to the heavy calcium around here. It doesn't seem like anything you soak it in penetrates. The torch and the banging worked best. My garage smells like burnt rubber from the sizzling of the gaskets.
I'd like to know how to get the damn star off my old style RX. I know they thread on CClockwise, but even with a BIG sledge, and a block of wood, it won't budge! I've tried it right after using (hot), and also cold.....no results.
