HydraMaster DriMaster 2 Upholstery Tool Auction!
http://www.hydramaster.com/Products/Acc ... yTool.aspx
Hydra%20Master%20Upholstery%20Cleaning%20Tool%201.jp
g
Eliminate overwetting concerns and clean upholstery faster with the DriMaster 2 Upholstery Tool. Utilize the power of your truckmount rather than by-passing it. HydraMaster's patented DriMaster™ Upholstery Tool is unlike any tool you have ever used. Using new Jetless Cleaning Technology, it has no trigger valve, no spray jet, and never needs a second drying-pass. The solution is under constant flow, trained by the patented injector bar and slotted vacuum port system. The result is a highly effective cleaning tool that works without overwetting or heat loss. Even narrow areas can be cleaned without any overspray.
Less Operator Fatigue Durable, but lightweight, the DriMaster Upholstery Tool is less than half the weight of other upholstery tools. The new Jetless Cleaning Technology eliminates the need for a trigger valve so multiple holding positions are possible, lowering the potential for hand strain. No second pass, no over-spray, and high-volume water flow all contribute to the efficiency and speed of cleaning. Cleaning with the DriMaster Upholstery Tool is just plain faster. The high flow - low residual moisture effect of this new technology leaves the fabric cleaner and drier while greatly reducing the chances of damage.
Combine the high performance cleaning of the DriMaster Tool and HydraMaster's state-of-the-art cleaning chemistry and you're ready to treat most cleanable fabrics with fantastic results!
Exclusive DriMaster Features
·Patented jetless technology
·Solution is applied in a thin, flat stream for even application
·Cleaning solution is under constant flow, trained by a patented injector bar and slotted vacuum port system
·No trigger valve, no spray jet, and never needs a second dry pass
Contractor Price: $515
Auction starts @ $250 and goes up in $10 increments
Free shipping included!
Ends Wednesday 1/11/12 @ 7PM PST
Benton KY USA
From Darren's website posted on his profile:
Carpet Pro Cleaning & Restoration, Inc.
3503 Church Street, Stevens Point, WI 54481 | Ph. 715-341-3300 | Fax. 715-343-9810 | E-Mail. info@thecarpetpro.com
Ph. 715-421-5556 Wisconsin Rapids, WI 54494 | Ph. 715-845-9300 Wausau, WI 54403 | Ph. 715-256-9001 Waupaca, WI 54981
Yes quite real!
K P
Ken Snow said:
Is Darren a fake profile? If so not only is it classless, but also illegal.
I was going to bid but now Im afraid to.
Benton KY USA
Marty said:
Who removed MY $360 bid?
Which, by the way, was BEFORE Terrys!
Mod logs show nobody removed or touched your posts.
It's easy to drop your post if you accidently tab to Preview instead of Submit.
