Hydro-force solvent pro pump up.
Cleaning out my shop. Found this sprayer but doesn't seem to hold air. As you pump it up, you can hear the air hissing out. Does it have a gasket that can be replaced where it attaches to the filler neck, or should I just toss it.
it's just a viton O-ring isn't it?
well stocked hardware stores will have one
or just go to Home Depot and get another one for $12 bukz instead of $30
HM hasn't had a pro-grade 1/2 gal sprayer since they discontinued the wide mouth one years ago
Reactions: Jimmy L
Thanks, I'll check next time I'm at home Depot. 2 local suppliers haven't a clue even I know I bought it from one or the other.
Shelbyville TN
The sprayer you have is a B&G model similar to the one in the Amazon post. The Solvent Pro model had Viton gaskets and seals instead of the buna rubber that is in the Amazon sprayer.
I agree with finding a Viton O ring at a local hardware if you can.
