steamron
Can I put a check valve on the end, it's dripping quite a bit?
Thanks
Thanks
I don't see why not but probably better to repair or replace the trigger handle or valve. Or just use the shut off on your solution line.Can I put a check valve on the end, it's dripping quite a bit?
Thanks
