hydroforce fills up
K
KOOSER55
For some reason my hydroforce fills up when its hooked up. If im spraying then i sit it down for a min the water from the sloution line fills it up or over fills it. is there a valve or something on this that i can replace?
Farenheit251
fOR LACK OF SOMEONE WHO KNOWS BETTER BEING ONLINE NOW i WILL REPLY NOW. Unscrew from the cap and there will be a silver ball,spring and black o ring. Check O ring for damage and sometime just putting it back together helps as the ball may be jammed. Beware the spring goes in the way it doesn't fit. IE large end first. If that doesn't work you need a rebuild kit cosisting of those parts. Use a pen or similar to get the spring inserted.
packfancjh
Chris Hagen
If your Hydroforce is back filling the injector valve needs a rebuild or needs to be replaced.
