HydroForce Pump Sprayer
glenboy
GLEN
i have used the blue 3 gallon pump sprayer for at least 10 years,it is see through,has a plastic wand that is easy in the home when it drops or hits a wall.if it gets stepped on it doesn't bend.so recently i ordered a new one from my supplier and when i received it i noticed it was smaller and the hose was almost a foot shorter.:afro: So i returned it and they agreed to send me a better sprayer at no cost.but even the new sprayer leaks around the tank hose clamp.and its worse in the cold.so i let it warm up and it still leaks.i am loosing pre treat all down the side of this sprayer.its tank is black so i cant see how full it is inside van where i do my Mixology.and i also noticed the tank is re designed to a 2.75 gal tank with .25 for air space.so now instead of 3 gallons of pre treat i can only mix 2.75:hopeless: i am wondering WHY???? and Who uses what other pump sprayers with less issues
davendana
d Jackass
I use the 3 gal Gilmour sprayers that are green. No issues
Sent from my SCH-I545 using Tapatalk
