Hypro pump 2340-B-P question
L
Larry B
Have a Hypro 2340-B-P pump that is leaking oil and pressure drops from 600psi to 200psi when you key the wand, is it worth rebuilding?
If I buy a new one will my clutch change over to the new model or will I need to replace it also?
Sent from my iPhone using Tapatalk while eating raw fish
Shawn Forsythe
It's hard to gauge every situation without a teardown, but we rebuild that exact model quite often in our facility with identical symptoms, since it happens to be the most prevalent model we find on Steam Genie units. There are quite a few Steam Genie units in Southern California.
L
Larry B
Shawn can you tell me who to contact for a rebuild kit?
L
Larry B
Thanks Shawn
L
Larry B
Hey Shawn
Speaking of SG where did the big switches come from that were used on the last 47 direct drives? (Blower speed, power, pump)
