Hypro Pump
Goldenboy
Mike Waldron
I havea Hypro Power Plus 2359B-P it has been leaking oil. How hard is it to fix? Pressure side is fine. No problems other then it leaks. Its about a 800 dollar pump. Should I let the pressure washer shop fix it? Had it for awhile. Look forward to your responses you Hacks.
Golden Boy
KevinD
Kevin Dumas
Golden Boy
Not hard at all if you are a bit mechanical and can keep things in order when you disassemble it.
If you are going to put oil seals in it I would put a plunger kit in also while it is apart.
