I am doing a full service cleaning job on the Legend
daniel@procarpet
I am going to take the hxers out and clean them,the housing, and clean and degrease the entire unit.
I noticed the machine has a temperature sensor. How can you tell if the sensor is working properly? I belieive I heard a bad sensor can make the heat output too low.
Also I may need to get a gasket or two for the hxers. Where is the best source to get them besides Interlink?
http://www.interlinksupply.com/index.ht ... 9+++++++++
daniel@procarpet
Someone has to know something.
My supplier mentioned something about getting a bath tub liner etc. that can be cut and used as a gasket. It can be bought at Lowes etc. What am I looking for exactly?
Any ideas?
The gaskets I have are in decent shape, but I would like to replace them as I am making this machine like new.
Luis Gomez
Luis Gomez
Look for the heat exchanger gaskets in the plumbing supplies section @ home depot. They are about 8"x8" squares of rubber (red) for 2 or 3 dollars.
Luis
daniel@procarpet
That is the answer I was seeking.
Thank you so much!!!
You just saved me about 150 dollars.
I believe you are missing several temperature sensors. Yes there is on on the back side of the exhaust HX.
Do you not have a manual? Prochem is pretty good about having them online.
