Lonny
- Joined
- Oct 2, 2008
- Messages
- 311
I am going to add another vac to the EDIC. The plan is to have 2 sets of 3 stage motors run in series, each with its own air feed into the waste tank-I gotta set the #2 up. I will have them on their own switches so that when switch one is flipped one vac from each set is on, then switch two will control the other set. The pump will need to be on its own circuit now though. SO, the question is, which vac motor should I go with? I am mostly concerned with amperage draw here.
Thanks!
Thanks!
