All you folks who say that your Truck Mounts at 230 all the time, I think you may be wishing it did.
Your in a house and set the wand down to go to the truck, it takes you say 20 to 30 sec. (maybe longer) to get to your truck. That time can make a difference in heat and cause the unit to raise the temp.
I did and little test at a rental, 24 degrees that day.
Truck parked outside and large window, truck was on sidewalk next to window and I could see the unit. Prochem Apex at 425 psi, I would trigger the wand and clean a small area . temp would drop to 200, let up on the wand and it took 25 sec. for the unit to rise back up to 235.
Another 20 seconds on the wand and it dropped, waited again and it took another 25 or so sec.
I read some one say that they ran 2 Rx20 over 600' at stayed at 230, by the time you walked back 600' the temp jumped back up.
Plus you have to look at how cold is it out, close the doors on your van the best you can to help retain temp. How about the cold ground the hoses are laying on.
