I need a glide.
daniel@procarpet
I tried the holed glide and did not like it.
The slot glide is great on my quad prochem wand.
I have an un-glided wand that I need to get a glide on. I am leaning towards getting another slot glide, but I kind of want a hybrid. The problem I had with the hole was it would not pick up the smallest piece of lint and the design made for overspray. The slot eliminated all that.
My question is why should I get a hybrid over a slot?
I have my doubts the hybrid will clean good, but then again it doesn't have to be my primary wand.
It could also be my favorite.
The second wand is used mostly for dual wand cleaning. Will a hybrid suffice, or should I just get a slot?
It would be nice to have to hybrid for rugs.
Un-glided is wearing my help out when we dual wand.
I put that glided wand in his hands and his jaw dropped. He turned into a semi pro almost instantly.
Ron Lippold
I run the high brid and love it with hig flow and a slow pass long stroke. :shock: :shock: shiteatinggrin
daniel@procarpet
How about a picture of your wand with the hybrid glide.
I want to see the edges.
Ron Lippold
its the standard gile but worn out i need some new ones lots of mile on those babys.....on a ti wand
daniel@procarpet
They seem to work better once they are broken in.
Kind of like shoes.
Ron Lippold
no a fresh glide is like a new hair cut, you cant even tell you got one.............
steve g
I can't understand why anyone runs a hole or a hybrid glide, they can't even pick up a blade of grass that gets tracked in from a trip out to the truck. the hybrid to me worked just the same as the hole glide. I have had great luck with slot glides, never had any problem with them.
Ron Lippold
steve there is a tilt thing you have to get going on i can pick up almost anything except a big vibrator................. shiteatinggrin shiteatinggrin shiteatinggrin shiteatinggrin shiteatinggrin shiteatinggrin shiteatinggrin shiteatinggrin
Daniel;
Here is a 12" wand with Hybrid GG:
The slots are oval in shape.
BLewis
Billy Lewis
I started with the hole glide
Moved up to the hybrid for restaurants
Now use the slot glide, and yeah Ron it helps to learn the turbo tilt and apply to picking up the big articles
Even the holed glides have larger slots on the sides which when doing the "turbo tilt" pick up anything else. But honestly..if I vacuum properly, I don't have to go after the chunky stuff. And the hole glide will pull just as much sand, small hairs out of the carpet, and I have the lint filters to prove it.
But if I have a problem where there maybe chunkier items, I can always fall back on the RDM, or bring my semi glided prochem quadjet.
Ryan
You know if you get a hybrid and don't like it. It's not so hard to take a drill press and turn it into a slot glide.
truckmount girl
better to just exchange it for a slot instead.
take care,
Lisa
