I need a new urine light
steve frasier
Interlink has a high power LED unit for about $415, it has big LED lights
JonDon has UV light for about $470
I bought a LED flashlight type one last year at Connections, small lights and it is a piece of crap so I am kind of against the LED types
any one tried either one, I want it to able to be used in daylight
Captain Morgan
Bill Morgan
There was a tread here about a week or so ago about this same subject. Larry Cobb has a UV flashlight style urine light. I think Frazier bought one, it can be used in normal light room conditions and it's only about $250-280. You'd have to check Larry's website FMI. I need to get one too and I don't like the LED Style either.
Good luck!
GRHeacock
If you do a lot of urine work, get the best. The cost of an item is a business expense, and deductible anyway, so why not get the best.
If you only do a little urine work, a fluorescent low power one will do the job. Cost around $35.00, but can only be used in a darkened room.
Gary
One thing I would say regarding the LED UV lights.
Most of the lights utilizing many of the small 5mm LED's are using Chinese LED's.
They will fail in a short period of time !
The high-power UV LED's are made here in the U.S., and will last for thousands of hours.
I have been building them for years.
Spurling
I had a customer pull one out she bought at a pet store for $25 ..about 10 in long and bright .. made the pee stains pop .. even with a medium well lit room .. battery operated
Brian R
Brian Robison
Stand to the right a little
and Ur In light.
It just had to be said.
I think I need to see a professional.
Bump
Was searching the board for the best lights. I bought the $139 from Cobb's at COnnections but it really isn't bright enough.
I want a light that WILL show the urine if its there.
Saw one at Interlink, http://www.interlinksupply.com/index.ht ... ++++++++++
Saw the ones at Cobb's
http://www.cobbcarpet.com/uv.html
Jondon's
http://www.jondon.com/catalog/advanced_ ... ht&x=0&y=0
What about the yellow glasses? Are they needed? Would they help with a weaker light ie the one I already have?
Any others?
Gary
Agreed, Gary.
A good tool is worth the money.
What we are trying to determine is which is the best?
Do you have a preference?
Which is the best?
Also the more LED's the better.. 51 and higher is a must! 128 are awesome!!!
handdi
Randy
i bought one from cobbs year or so ago
come with a recharger 200 bucks or so very happy with it
Definitely get the amber / yellow glasses. Not only do they protect your eyes but the glow will be much more noticable in many lighting conditions. You can get about a 20% improvement in performance for $5 or $6 dollars.
steve frasier
this thread is 1.5 years old, stop replys
I bought a rechargeable LED light off a detective web site. With 2 pair of the yellow glasses. One for me the other for the customer.
rhyde
rhyde
correction it's not a urine light it's an ATM machine .... :roll:
The thread was "started" 1.5 yrs ago. Bumped it for some updating as to what's available today.
Where do you buy the goggles? John? Larry? Interlink?
steve frasier
I got the extra pair of yellow glasses from local interlink dealer
Scott is correct with his advice. It actually made the crap flashlight I got at connections almost usable in a semi dark room
I want the ATM machine.
don't we all
