May 24, 2012 #1 D daniel@procarpet Guest I need a y connector that will convert two 2.5 inch hoses down to one 2 inch hose.
May 25, 2012 #2 A Able 1 Guest I have never seen one.. You could look for a 2.5" Y (more like y out of PVC)then just use a reducer?
May 25, 2012 #3 D daniel@procarpet Guest Able 1 said: I have never seen one.. You could look for a 2.5" Y (more like y out of PVC)then just use a reducer? Click to expand... Sounds like a good idea to me. I'll check it out.
May 25, 2012 #4 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,877 Name Jim Martin a single 2.5 reduced down to 2 inch is all you need...... and if your hose run is not long enough to worry about pulling the 2.5 off..it will hook straight to the box...
May 25, 2012 #5 L Luis Gomez Member Joined Sep 20, 2007 Messages 362 Name Luis Gomez Take a 2" Y connector to a muffler shop and they can spread the 2" y part to 2 1/2". Make sure you have 2 1/2 cuff so that it can be sized. Luis
