I solved all the world's problems...
Dwain Ray
Near perfect soulition valve only missing the off stop. I like the valve you gave me to try. The only thing i can find falt with is the handle. When it gets dragged on the ground it bends and has to occasionally bent back to allow the handle to clear the valve body to be turned completely on. Sooner or later it will break from metal fatigue. The round handle would be a perfect wand valve if it had an "off stop" ive used valves before on soulition lines that rotated 360° and under moderate to high pressure tend to be a pos to turn completely off to disconnect because the slightest misaligned and the pressures back on the quick connect.
Stops create problems.
The indicator line will help you figure it out.
