- Joined
- Oct 6, 2006
- Messages
- 117,226
oh, @The carpet cleaning professor , will you please send this idiot some, thanks!Didn’t get it either
We can go to Waffle House and I'll buy you breakfast. We'll eat extra large meat omelets in homage to Mikey.No
He never offered anything free
I never expected anyoh, @The carpet cleaning professor , will you please send this idiot some, thanks!
Give him another month and he wont send it, either.I never expected any
I figured it was just you being you
As a prespray on delicate rugs, as a prespray or encap on delicate upholstery. I also shampoo it in with a 175. Very effective.How do you use your LST?
Try the SS next time, same cost, more effective, no sticky residue if VLM'd and easier to pourAs a prespray on delicate rugs, as a prespray or encap on delicate upholstery. I also shampoo it in with a 175. Very effective.
Good griefs.Can it be used as an encap?
yesCan it be used as an encap?
Same cost?Try the SS next time, same cost, more effective, no sticky residue if VLM'd and easier to pour
When you compare dilution ratios the silver solution is even cheaper..yes
Same cost?
I sure will man Just need shipping informationoh, @The carpet cleaning professor , will you please send this idiot some, thanks!
yes
Same cost?
Yep you nailed it.Its no secret the Silver Solution and ChemMax's "LST" are made by the same company...
there is some whispering going on about their similarities so lets do this...
LST is a liquid/sludge designed for use in soaking tubs or used as a shampoo through a 175/Cimex in a wash pit. The wide mouth jug is used to facilitate using a scoop as it doesn't readily pour out.
LST is 6 to 8 ounce a gallon. Cost is $40 a gallon. SS is $100 a gallon and is 1 to 2 ounces per...
LST uses different Fluorocarbons and far less of them
LST and Silver Solution will work equally on light soil situations but SS will outperform LST in heavy soil, and leave less residue
Both share the same SDS legally but ingredients are not balanced equally between the two and nor do they need to be to share the same SDS
This stuff has been around the 70's and was an Ed York fave.
There's room for all man.
Can you spell out the differencesbetween silver solution and lst? What makes silver solution so expensive.Yep you nailed it.
We knew when we released the product that people would feel that they had unlocked the mysteries of the universe and say things such as it is just this or just that.
But there is differences.
We have more products coming out soon as well. Our CLO2 deodorizer where we worked with a completely different manufacturer.
Thunder pree spray, alkaline rinse and VLM cleaner(non-film forming) ph8 Also can be used as a additive for silver solution
Lightning alkaline pre-spray for more where more aggression is necessary ph10.5
Rain Which of course is our acid rinse agent It's designed to PH4 it can handle a lot of tasks were you normally be afraid to tactile the fiber type
lol...I already did.Can you spell out the differencesbetween silver solution and lst? What makes silver solution so expensive.
Fluorocarbons are incredibly expensive The more you use the more it will costCan you spell out the differencesbetween silver solution and lst? What makes silver solution so expensive.
Exactly Mikelol...I already did.
and its the same price as LST, if not cheaper.
YFCC's
It's just at $100 a gallon, you may be pricing yourself out of the market. Even with a high dilution ratio. Translates probably $150 a gallon for Canadians including the exchange rate, shipping, duties and taxes.Fluorocarbons are incredibly expensive The more you use the more it will cost
And the higher quality ones cost more
We had absolutely no intention of coming out with a cost-effective product first
We wanted to make the most effective product
Ldtbis $39 per gallon. Silver solution is advertised at over $25 per quart.lol...I already did.
YFCC's
Yes if not moreIt's just at $100 a gallon, you may be pricing yourself out of the market. Even with a high dilution ratio. Translates probably $150 a gallon for Canadians including the exchange rate, shipping, duties and taxes.
Tim, dilute some down so you can sell Canadians and US broke dicks a $29.99, 4 to 1 gallon version.It's just at $100 a gallon, you may be pricing yourself out of the market. Even with a high dilution ratio. Translates probably $150 a gallon for Canadians including the exchange rate, shipping, duties and taxes.
Not hereThere's room for all man.
yes!Silver solution is advertised at over $25 per quart.
Yes I will dump a quart of silver solution in a gallon of water and add an add filler You could nickname me RobTim, dilute some down so you can sell Canadians and US broke dicks a $29.99, 4 to 1 gallon version.
You miss the point Mike. 4 quarts at $25 each is $100. 1 gallon of LST is $39. I'm all for new products that make cleaning easier and I trust products from Chemax, I'm just saying it's a little pricey for the average carpet cleaner. Even for the premium cleaner.yes!
4 quarts makes one gallon.
holy crap Ron.
Ron, fire up the calculator and tell me and Marty how many gallons of RTU (ready to use) SS a gallon will make at 2 ounces per gallon4 quarts at $25 each is $100. 1 gallon of LST is $39
