- Joined
- Oct 9, 2006
- Messages
- 64,833
- Name
- Rico Suave
LOL
								Saiger" data-source="post: 4446872" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">What is the HG set at on your Butler?12 flow here....all day long...
SS Super Spinner is 4 flow, but probably equivalent to my 12 flow....
Butler High Heat with 47 Tuthil and I run 2.5 inch hose for the first 100 feet....but longer runs...as much 2.5 inch as I can toss in the van for that day....
Just so no one thinks I am cheating
Matt
Did you secure a new Cimex?
I'll race both of you soakers with it..
Saiger" data-source="post: 4446964" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">That might be why mine works better at 7.5 flow. My hg's are set at 12. I would go higher, but my manual says to keep it at that. I don't want to void my warranty.15-16 factory setting (which it is set at)
Matt
That's how great a Cimex is..
With a broken foot I could still out (appearance) clean you two hot water geeks.
The area ill look better the next day and I'll be drinking Mojitos by the pool while you are still winding up hoses.
For this debate to go any further I'll need to borrow Guerkink's snakes
I'll make believers out of all of you..
Saiger" data-source="post: 4446989" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
When I went high flow, and held the trigger for a long run on trashed carpet, there was more water in the hose, and my vac relief opened up, causing the suction to slow down. If my hg's were set higher (13-14), I feel that the higher flow would perform better.
That's why I'm only gonna clean at 7.5 in nashville.
But I still look forward to competing with your zipper, LOL.
I'm certain it would, but @doylebloss might fuss at me for going over the limit on what their manual tells me to set it at. I will if he tells me it's ok this one time, just for some healthy competitionSet the Vac higher to maintain more CFM thru the wand head.
Less air will be lost thru the relief valve.
I think you will do well against the Zipper ( with the same 15" hg) .
Nahh, I'll leave it at 12hg. If I win, I can rub it in that my blower was set lower. If I lose, I'll have an excuse as to why I lost. It's a win win for meI'm certain it would, but @doylebloss might fuss at me for going over the limit on what their manual tells me to set it at. I will if he tells me it's ok this one time, just for some healthy competition
LOLNahh, I'll leave it at 12hg. If I win, I can rub it in that my blower was set lower. If I lose, I'll have an excuse as to why I lost. It's a win win for me
Let's tie your gimpy leg to Marks gimpy leg and see what you can do.That's how great a Cimex is..
That's the whole reason I started this thread. I need to see it myselfZipper would have been done in 4-5 minutes... inoshityou
I agree. It won't be long before I open the wallet for a Zipper. My shoulder and lower back is holding up fine for now. When go to bed with an ache, and wake up with the ache still there...the Zipper crew will be sending me one.Matt, that was incredibly painful to watch. Now that you're young and full of piss and vinegar, well piss anyway, you can get away with slinging a big wand like that. It will catch up with you in your later years. Running a 17 inch Zipper up and down will be the same or faster (probably faster) without all that energy expended. I did 10 hallways, one office today, aprox 6000 sqft. with one helper pulling hose and organizing things and we were done in 4 hours. All cgd, presprayed and rinsed using a 12 inch wand. I am a little sore but using a wand like that would probably put me in the hospital.
Use it extensively in Nashville. Save your body, don't wait until you need it.
It flushes better and dries faster with less fatigue than slinging a wand. Only an idiotic fool would ignore a tool that benefits the client and yourself.
But do what you want...no pressure.
