Ink Exit- Nice!
I've been using "Ink Exit" lately. [Sapphire. Chemspec].
Very nice product, even removed some old ink (or marker) stains that went through hot cleaning before. In the past that meant a permanent stain, it got it out.
It will not get every single ink/marker stain out, but which product does?
And to boot, it does not have a noxious smell (like a touted ink remover of an unnamed competitor) that takes a few generations to dissipate and reeks solvent for a long time. Strong solvent odor is not a good message to send to the client, as far as I'm concerned. Also, so far, it did not create a halo (ring around stain) and or cause any de-lamination.
Granted, I have not used it for a very long time, so this review is not long term based.
Very good product.
As far as your spotting arsenal, it's an Offer you shouldn't refuse.
Bryan Thomson
Bryan Thomson
Have you tried the other Chemspec spotters yet......Stain Exit and Red Exit?
The aspect of the Chemspec Ink Exit I like the most is, it doesn't cause the ink to bleed / spread out.....it put the ink in an emulsion that after it releases from the fiber "stays put" for easy extraction.
Nothing like it, in the market today!
Pat Muller
Pat Muller
Hi Ofer,
I am glad to hear your experience with our new InkExit.
You are right in regards to low odors as it is a water based ink stain remover and the response that we have received is great.
Reactions: Bob Pruitt
jack zerkie
I just used ink-out and really works great no smell. but I used it for red wine removal from a carpet. cleaned it all. The red wine was gone just right now just as I sprayed it on. Then I extracted with water rinse. No wine showing now. I found this item at a local janit. store and they no longer carry it. The item is called unbelievable inkout, but hey make other items. Core products in Canton Texas 1800-825-2673 they have some outlets but give your zip to find out where. jz.
