Jan 25, 2007 #1 B Brian L Member Joined Oct 6, 2006 Messages 2,825 Location Hollister Name Brian L For those of you that use an inline sprayer, which has worked out better for you: Hydroforce or Spraymaster. Adjustable or non-adjustable. Adjustable has always been a problem for me.
Jan 25, 2007 #2 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 30,655 Location North East Ohio Name Larry Capitoni both adjustable and non have been a problem for me ..L.T.A.
Jan 25, 2007 #4 C captaincarpet Member Joined Nov 14, 2006 Messages 545 Location Kennesaw Ga. Name Thomas Cermak I like the spraymaster better, it is more user friendly, 7 qt. wide easy fill jug, swivel on hoses,IMHO
Jan 26, 2007 #5 G Guest Guest How do you deal with that POS lid on the 7 quart??? 2 of them now made me very pissy. Chad
Jan 26, 2007 #6 F FastEddie Member Joined Oct 19, 2006 Messages 435 I think Sal upgraded to a better lid, like the ones that come on a 5 gal chem jug.
Jan 26, 2007 #7 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,836 Location Benton KY USA Name Lee Stockwell Replacement 7qt heavy-duty jugs are a bit under $20 including UPS from CA to KY. We like the new ones very much!
Jan 26, 2007 #8 G Greenie Member Joined Oct 7, 2006 Messages 6,820 wasn't the lid, the jug it's self was flawed, weird thread pattern, blame it on the chinese, or maybe just uncle knock off himself.
Jan 26, 2007 #9 C captaincarpet Member Joined Nov 14, 2006 Messages 545 Location Kennesaw Ga. Name Thomas Cermak we must have the newer jug, it has a large opening with a good cap like a 5 gal. chemical jug.
Jan 26, 2007 #10 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin 7's are great..don't fall over.... etc,etc......... Take the white gasket thing out of the cap and try it I removed mine and the cap works much better and it still does not leak with out it... seats on the jug nice and tight with a easy half turn........
Jan 26, 2007 #11 Mikey P Administrator Joined Oct 6, 2006 Messages 112,879 Location The High Chapperal The solvents in yor pre spray eat up the rubber gasket. I poured an epoxy in the trough instead and it works pretty good, not perfect but way better then the O ring.
Jan 26, 2007 #12 Jimbo Member Joined Oct 7, 2006 Messages 2,197 I'm back to the non-adjustable hf model...hae use the adj spraymasters for several years...just got tired of them going kaput...so I grafted the spraymaster longer sprayer with a hf dema valve.- Jim
