Woa there people.. ON CGD.. action back or even unitary back.. yes seam seal after cutting but you need to use a commercial seam sealer as well. The process should include pre cutting the seams, troweling out the glue under both pieces to be seamed, lay one piece in and roll, and then apply a small bead of commercial seam bond like roberts 8015 along the edge of the carpet then slowly work the other side into the seam using a kicker to adjust and butt the seams together and working them together with a carpet tractor.
