IPS PRO Sprayer Fresh Out Of The Box, Initial Impressions
Goomer
Frank Mendo
The tip doesnt move, just the logo'd colar...
Instruction manual online..................................
http://www.ipspro.us/content/20-ipspro-mounting
Reactions: Bob Pruitt
Goomer
Frank Mendo
I changed the batteries, and after 4 hours of charging they were hot.
So there seems to be no smart charging going on there
Seems like it should have some type of smart-charge features by the looks of it.....assuming it works right.
I bought one about a month or 2 ago. It says on box it has the new improved seals
2nd, it's recommended to rinse with water after every use
So, if you have employees , you can forget that from happening every time
We have gone back,to,the battery sprayers
for all the battery operated crap I have..these seem to charge pretty quick and they hold there charge..I was surprised at how long I could go before it started to slow down...but they do get warm...but most fast charge batteries will...
I keep a water bottle beside the machines..and after every job I always rinse it out...but its just common practice with everything I use...and when I had employees....they were taught from the beginning that was what I expected them to do..and I don't recall any issues...
It looked like a fragile cluster fook to me. :shifty:
honestly....so far I am not seeing a problem with it....its stronger then what it looks...I had the pump head in my hand and took a good look at everything and how it ticks and it is a pretty good design...the plastic is not that fragile and I really dont think the threads are going to get worn .or destroyed...by normal use..
but if it is not going to be taken care of then they get what they get......
I really like this sprayer...and like I said...if the new seal are promising...then I will gladly buy 2 more....
Why would you need three?
I sure wish I could use the brass Lance, at my height it would be nice
one for the other truck and one for things around the house....
you can very easily get a brass fitting for the end that adapts to a 1/4 inch compression and put a any length you want ...then just adapt the other end for the jet..
Latest Auctions
