Is my glide toast?
joeynbgky
Bowling Green
Joey
Here's some pics, its a greenglide that's a year old. It has knicks, and the glide itself is no longer even. Deep wear groves to.. will this affect recovery?
Sent from my g2 using tapatalk. Whofat
Arizona
there is a lot of life left in that thing...sand it down and put it back on....
lance
Back relief helpers work better when they are rounded. That is why they come that way from the factory.
Here's some info......
There was a point in this Ad somewhere, FLAT and a big ass slot, and additional grooves does Not GLIDE very well, nor dry very well, so is it really a stair glide?
Honestly..it's kind of the Anti-glide, let's see if Mikey would like that on his Vortex?
As for wear, keep your teflon glides Round as best you can, a little block of wood and some 80 grit or a Rasp will make short work of keeping them round, then follow with some 120 grit, it'll also clean them up nicely. keep em' round and they will push easier and extract better.
Utah
holy chit, your fine....TONS o life left...it helps with aggitation when its a little beat up...
they come rounded because they buy the round sticks, not that they get squares and round them....
with that said, and the fact you used the G word....be ready for cease letter
lance
i know how to use the search button and copy&paste.
Those are greenie's words not mine, so buzz off.
rwcarpet
Youngstown, Ohio
Robert Hodge
At first look....I thought they were Old Bawbs teef.
Glynn
Sand it down, loads of life in it yet.
Just DONT breathe the dust in when your sanding it !.
steve g
herriman, UT
steve garrett
I run mine until they fall off, so far I have worn out 1 in 6 years, the one I have now has about 1/3 life in it still. I do find it odd that the edges are worn so much worse than the middle.
Wi
Keith
Yeah, tack strips eat them up... :evil:
steve g
herriman, UT
steve garrett
wow, I even use mine on concrete sometimes doing flood work, and I still get YEARS out of mine.
joeynbgky
Bowling Green
Joey
The glides still good just wandering if it will effect recovery. Im gonna get ahold of lisa and buy another one im picky.
Scott S.
PA
Scott
I machine mine when it gets.really flat. It being rounded some does make a.differance.
