is peroxide "green"??
is peroxide "green"
is it healthy for you??
ever get any of the hi-test peroxide (20-30-40 vol) on your skin??
wonder if it does the same thing to your LUNGS while you're atomizing/spraying and BREATHING it???
San Francisco, CA
I am sure Larry that at that level it is not healthy for you.
However, when do we actually atomize a pre spray?
I assume that using a hydra-force does not atomize it. Fogging may.
So when do we actually atomize products?
Ne
Is ammonia green too?
It occurs naturally.
Are farts green too?
John Watson
You aint English, your Russian, Aleutiq, Norsk and Army plus a lot of Heinz 57 mixed in.... :lol: :lol:
Bo does stink tho, Mikey gots one of those Limey things too. hims name is Diesel,,,
rhyde
Portland, Oregon
rhyde
Erskine Allin said:
is peroxide "green"
Don't huff the stuff!
On a side note about green and peroxide !
Commercial hydrogen peroxide is made with 2-alkyl-anthraquinone by catalytic hydrogenation gas with palladium.
Hydrogen gas is made from natural gas by steam reforming
2-alkyl-anthraquinone is made from phthalic anhydride & ethylbenzene, phthalic anhydride is made from ortho-xylene and naphthalene
-ortho-xylene is derived from Crude oil
-naphthalene comes from coal tar and a smaller amount from crude oil
ethylbenzene is made from benzene and ethylene
benzene comes from Toluene which comes from coal and crude oil feed stock
ethylene comes from steam cracking oil and natural gas
Green earth friendly Peroxide is crude oil with a wholeltta energy thrown at it.
ACE
Lawrence, KS
Mike Hughes
The short answer is yes.
Accelerated Peroxide is a patented blend of peroxide and surfactants that is an excellent antimicrobials /cleaning agent. They are preferred green antimicrobial in Canada and some European countries. The EPA has effectively killed the market for accelerated peroxide products in the states by lumping all antimicrobials in with pesticides and banning green labeling for antimicrobials in the states. Because of the EPA, hospital grade peroxide disinfectants are not available in the US.
http://www.virox.com/ahp/faq/default.aspx#technology
chrisbaily
Yes it is green in color..it can b harmful if used in a large quantity for cleaning carpets. So using only 3% peroxide to sterilize cuts and abrasions - the fizzing you'll see occur is normal.
