Is there a green seal certified encap product?
Is there a Green Seal certified encap or bonnet cleaner?
Do some of you use Procyon as a bonnet cleaner?
Other products?
Bridgepoint's Encapuclean GREEN double strength
Drive on down to the local Interlink supplier and pick up a gallon.
Smells good too.
Brian R
Brian Robison
A few years ago I used Procyon for bonnet cleaning. I was surprised at how well it worked.
I thought that may be the way to go Bryan. I once did a bonnet cleaning with SoapFree and it worked quite well.
And since I am not yet a true believer in the encapsulating Fairy..........miracle........
Procyon have all the certificates and the carpet I bid on is not very heavily soiled.
Derek
Derek
Procyon isn't an encap tho.
good thread, i didn't know there was a "certified" encap.
Brian R
Brian Robison
No, Procyon isn't an encap...But it was still a good cleaner....Like Chem Dry but way better as far as the "process" goes.
I used to TM, Porty, bonnet with Procyon all the time.
Eats brass...But it worked really well.
It would look better and better as it dried as well.
Derek
Derek
now i see Procyon mentioned in initial post.
yea the liquid Proc worked good for me with OP...not great like current solutions, but good.
RGH269
Bobby Hales
Brian did you use Plus, Extreme or the regular? That probably explains what happened this week to my flow meter and how the brass looked when it was taken apart.
Brian R
Brian Robison
I used the powder years ago so I think it was just "regular".
I did try the Extreme when it came out but at the time it started getting harder to order so I switched to a local brand...Which was horrible.
By the time I would have gone back to Procyon, I started subbing out and sold all my equipment.
But if I were to HWE again on my own I would seriously consider it...Even with the brass issues.
But for now I Padcap and love it.
But that's another story.
ACE
Mike Hughes
Whittaker Crystal Dry Is top of the line Juice, but pricey. I diden't used to be very impressed with there cchemicals untell I stopped using their CRB to encap. Crystal Dry kicks butt with the cimex
