Aaron Richards
- Joined
- Feb 26, 2008
- Messages
- 237
for removing fairly fresh oil stains from a concrete driveway?
Doug D said:fix the oil leak on your van. you don't want to go around spotting up peoples driveways!![]()
Aaron Richards said:[quote="Doug D":3v2rkunb]fix the oil leak on your van. you don't want to go around spotting up peoples driveways!![]()
John La Rue said:Sprinkle kitty litter liberally over the spill. Grind in with your boot. Dwell time is variable, depending on how deep oil has penetrated into concrete.
Kitty Litter works but first pour mineral spirits onto the oil spot then follow with the Kitty Litter, let sit 12 hours, shovel off, spray degreaser, rinse, repeat if necessary.
