Is there any product to neutralize a perfume/strong scent
San Francisco, CA
I have a client with a heightened sense of smell that had a urine on the his sofa (drove him crazy.) Had a deodorizer put on his sofa. He does not like the deodorizer scent.
Any product out there to neutralize the perfume (deodorizer) smell? And not by adding another scent.
Benton KY USA
Re: Is there any product to neutralize a perfume/strong scen
Get the cat, a bowl, an eyedropper, and a spray bottle.
You obviously put on too much deodorizer.
Now you will have to carefully put just the right amount of cat piss back on the couch to reach that magic balance.
FB7777
Hydrocide is the least scented product I've found.
Goomer
Bronx, New York
Frank Mendo
Maybe you could rinse most of the deodorizer out with plain water before adding anything else that the guy will surely smell also.
San Francisco, CA
I actually pre-qualified deodorizer scent with client prior to application, had him sign that he understand that the scent will take a while to dissipate. Also applied deodorizer exactly as per manufacturer's instructions and rinsed the sofa afterwards. The client knew exactly (and signed) what the potential issues may be.
However, I would like to see if the scent (perfume) can be removed faster than through slow dissipation, as I'd like to help the client that has a very heightened sense of smell. (he was going to replace the sofa, and trying to remove it would have been the cheaper alternative.)
Fred, you are right, Hydrocide does have the least offensive scent. However, I do not know if adding it after Odorcide is not going to improve it or just add one more scent.
I was actually wondering if spraying 3% peroxide may help in breaking down the molecules.
Also master Blend has a scent free deodorizer. Anybody try it to remove a perfume smell?
Ozone machine maybe?? what did You use in the first place?
Maybe rubbing alchohol misted on area and toweled off use a blower to speed dry!
Or fresh water rinse hydrocide has no scent and encaps so maybe that would work!
You'll have to experiment at home and let us know!
PA
I'm Rick James
I would just reclean it using a fresh water rinse.
ACE
Lawrence, KS
Mike Hughes
If the weather is mild, I would rinse it off OUTSIDE and tell the customer to let it air our /sun for the day.
San Francisco, CA
Well. I already cleaned the sofa. No need to re clean.
And anyhow most of the deodorizer is in the filling material and rinsing does not really remove scent.
Though yesterday he seemed a little upset about the scent, when I came back today he was actually happy with the results (no urine odor) and praised me for doing a fantastic job.
So far.............life is good :p
Go figure :shock: :shock:
ACE
Lawrence, KS
Mike Hughes
Yea, Come to think of it, The reason for all my call back is people just miss me.
Ne
Steampros , www.solutionsbysteampros.com sells a product called ODORCRYLIC which has no scent.
You can even mix it with the scampoos because it crystallizes.
Art Kelley
Clawson,mi
ascrubabove said:
:lol: :lol: :lol:
Quat A Lot!!!!
Quat A Lot seems to remove every odor in it's path. If I add it to Sunshine deodorant for added quats it removes the Sunshine fragrance.
San Francisco, CA
Art Kelley said:
ascrubabove said:
Quat A Lot!!!!
Art, I thought that Quat A lot has it's own scent.
Art Kelley
Clawson,mi
Ofer, the Quat A Lot has but a slight clinical smell, like rubbing alcohol, that dissipates quickly.
San Francisco, CA
Thanks Art, I'll give it a shot.
As a quat, I am not sure how it removes the urine. I know that it kills the bacteria, so that in the short run there will be no odor.
However, wouldn't the alkaline urine salt eventually attract moisture and the bacteria return?
Les?
