It’s Here! The Nautilus Portable Extractor.
X
xfgeek
Ford or Chevy, Series or Parallel. Both camps have their followers, and until now they had to be stuck with one or the other. However, our new AirFlow+ vacuum system allows cleaners to customize their portable to suit their needs
More...
So it does hard surfaces too? What's the PSI on it?
This is a plug and play system. You can put in any of several pumps at 200 PSI, 500 PSI or 1200 PSI. Same thing for which vacuum motors you want, heater or no heater, auto fill, auto pump out. Many variations available in the same shell. Components easily swapped out if you want to replace or upgrade in the future.
Aaabrightfloor
Heater?
So you are saying that I can put a heater in one with 2 three stage vac and a 1200 psi pump?
NO, you won't get a heater, two 3 stage vacs and a 1200 PSI pump in the same unit. Not enough power available. But you can pick and choose between various components up to the amp draw you have available. (Most homes and buildings now have 20 amp circuits and can safely run 16 amps leaving a safety cushion.)
thats assuming its not one of the older buildings with weak breakers that can barely handle 15amps. Been in some places where I was resetting the breaker every 5 min
M
Mardie
Did you have the fire depatment on speed dial?
Just ribin ya lol
