Re: Jeff Woods – Judson Installs Reengineered Heat-Exchange
Gene thanks for reading the post and your input . The low pressure switch was not the problem with this unit. Let me back up a bit, the name of this unit is the THERMALWAVE which indicates it should have alot of heat, it did not as it was more like a thermalripple.To get any kind of heat it HAD to run on dual wand. A waste of fuel and it put more wear on the engine and parts. To be fair I do run high flow. With the little giant#4 I get instant 240 degrees on idle if I want and have no bypass. No need to run dual wand setting unless I am dual wanding . The thermalwave was made with very good parts. Great engine,blower ,pump and frame .It is also a very large unit and when in a van it it takes up ALOT of space. When there is a problem you cant get to it in the van unless you have 3 extra joints in your arm and its no larger than a broomstick. I could not afford to take it to the shop 200 miles away and have it worked on every time it had a problem. The problems were coming out of the over complicated heat exchange control system. With the new set up there is very little to go wrong and if it has a problem I can work on it in the van and easily repair it myself. With all of the old parts removed its now like a 57 chevy, open the hood and there is not much there . Here is the bottom line , I now expect the heat system to last as long if not longer than the motor ,blower and pump and be just as trouble free. There is an added bonus that the little giant allows less strain on the motor and pump hopefully extending their service life. Woodsey
