CleanEvolve said:
My jets on my
Prochem Quadjet have been plugging way too often lately. What would be causing this? What should i be looking for?
clean and check strainer on the wand.
If the screen is blown in, replace the strainer.
(they're down right cheap at the farm supply store, BTW.
a 4 pack of brass strainers is $11 bucks at Tractor Central Supply
descale your TM
after descale, flush the solution line at start up.
all the time, that is, nit just "after" descale ..make it a regular routine
stick a empty QD in the end of the solution line, stick the line in the vac hose and flush for appx 30 seconds or more depending on the length of sol line.
then plug in your tool/wand and go to work.
