Jets on your Wand,
steamclean
I have a Prochem quad with a glide, I have two 11015 in the center and 95015's on both ends.
How often do you guys change out your jets?
Benton KY USA
It depends. Brass more often than stainless.
Two things to look for: spray pattern, and measured flow via bucket test.
Bucket test a NEW 06 flow combination into a bucket as a baseline comparison. Worn jets flow more water in a narrower more ragged pattern, leaving gaps.
Brass should be good for 1000 hours, SS three or four times that.
Louis
Modesto, CA
Louis
Put a in-line filter after the quick connect and put all 02 jets on it. I have the same wand and had the same set up. Changed to 02 SS jets with small check valves no clogs and jets last a least a year. You will like how you will be able to flush out the carpet.
Boca Raton
9504's on the quad , stainless, and i never change them. the flow and pattern look as good as new.
gene
gene
16 flow really?
Must be a Florida thing.
My heat would suck.
San Francisco, CA
danielc said:
Lee you're crazy if you think jets will last 3k hours.
Change them every 6 months to a year or 500 hours.
Lee is right.
Dan is wrong.
Nothing new.
Just pay attention to the cleaning results, if no issues, just keep plugging along. Chances are the jets are just fine.
P.S. Wasn't it Pink (as in Floyd) that said in "The wall"-
"Hey, cleaners!
Leave them jets alone!"
Boca Raton
Daniel the heat is just fine and going exactly where its needed. my gauge reads 220 at the truck which is where i keep it regardless of flow , unless i use 2 wands. a diesel burner solves that problem. :twisted:
gene
