Jon-Don Proxi stain remover
Brian R
Little Elm, TX
Brian Robison
Looks like stain zone from Pros Choice (I think it's pros choice)
It works really good on the organic stuff.....But if you have a ton of "organic" stains...Like urine....Why not use a cleaner with the same (or similar) stuff instead of just a stain remover?
They are very very foamy. They do not work as good as the two part removers for leaving on a stain. They work just not as good. They are intended to be applied to the stain, given a decent dwell time, and then rinsed.
I have better luck using sp (odor rescue or similar) mixed HOT and applied to stain at the start of job. Anything that remains gets hit with the two part.
I think that is the best approach.
Rochester NY
R.J. Povio
I might have to try that product.
I have used from Jon Don their Matrix Product line. They have a two part (like CTIs Stain Magic) called Advanced Stain Remover (ASR). It works the same as Stain Magic. I have used the two brands side by side and saw no difference on how well they worked.
I have not had success with Bridgpoints StainZone as I have with ASR or Stain Magic.
Ross Buettner
Green Bay, WI
Ross Buettner
I'll say it till I am blue in the face.
Nothing has really been much better that Matrix all around. And the stuff is must more cost effective. I've found a few things even better than any as well.
Boca Raton
it's just 40 volumne diluted in a small bottle at a premium price. you can buy your own and mix it to your liking. we go thru about 1 gal a week. a case works out to 17 ea. the brand is roxy a local cleaning company bottles it. wouldn't be without it.
gene
Shelbyville TN
Thanks for the plug, but that is a Bridgepoint product not CTI.
