Judson diesel
cu
Cu
Les has released the the diesel .production starts in about 60 dsys
42 hp motor 5 m blower 210 to 220 heat
More later. ...I'm having a pint of Guinness right now
Now is that 210, 220 at the machine or the wand?
cu
Cu
Any pics?
Les put them up on his Facebook page. And a lot of the info about the unit. The set up has its own fuel cell , so no need for fuel tap kits . A very simple 4 bolt it in and get to work . You will need a waste tank . And your good to go.
This unit won't be for everybody. It ain't got any blue paint or sensors or computers sitting beside the motor and it is easy to get to everything for servicing . So it's a unit you can put in your pick up or box truck or both with out a lot of expense
What exactly is a 5M blower?
56, 59?
What sort if heat with two 08 or 10 wands?
Same blower in Becker's thermal wave, blueline was getting 525 cfm out of theirs, I believe.
depends on how fast you spin it.
is the HX coil inside...copper or stainless?
Looks lik a kickass machine.........simple and quick!
tmdry
Bill Martins
I wish it was a dual wand machine or at least have that option.
If it's a 56 it has the vac to do two modest runs but the hx wont keep up.
What if a guy put it in a diesel truck could he get a cell-les :smile:version?
cu
Cu
There may be a 59 blower unit coming . But it has to be simple to maintain and service and hold temps for duel wanding.
tmdry
Bill Martins
and a larger pump so we could handle two wands?
Why not be tank less so it can tap into a diesel box truck?
cu
Cu
I don't know the cost yet. The idea of having its own tank means us the rug sucking end user can do our own installs in any truck any time we want , you could plumb it into a trucks diesel tank if you wanted to also. But your back to paying fuel tap and larger install costs
But I guess now we have a choice.
Knowing what a big part my round vortex waste tank plays ìn its vacuum efficiency and effectiveness I'm pretty suspect of those bulbous mytee tanks..
Who here uses one?
looks like a pretty standard spun aluminum tank....offroad/vw/buggy/hotrod shops
