Judson O2 system
Ne
I use the gallon of O2 for furniture and recently rediscovered how good PC's Powerburst is.
GCCLee
East TN
C. Lee
Glad to see he uses it on Uph still,
Last I heard he was cleaning the skid marks outta his drawers wit it lol
mike r
Spartanburg, SC
Michael Ramsey
Les put countless hours into development of o2 products working with reps of several chemical companies. I know this because we were one of his main "testers" out in the field. That was quite a few years ago. We use his products as well as others as they work very well for us.
GCCLee
East TN
C. Lee
I ain't a blow n go product for sure.
Takes quite a bit to rinse it well, if you don't the re soiling is a bitch
mike r
Spartanburg, SC
Michael Ramsey
That's strange. We find just the opposite in this area. After normal extraction we've measured almost neutral ph. We have extremely soft water in this area. It has been several years since we have measured ph with this product however. Time to dust off the meter and get to testing.
San Francisco, CA
O2 is Great but it's a pain in the ass to rinse out....
I use it for upholstery only now.....
If it is that hard to rinse from carpet with high pressure/high flow, wouldn't it be even more of an issue with upholstery?
Or is it different down south?
Idiotā„¢
Every time I see some bulletin board cleaner mention something like poor rinsing I have to second guess their motives. Most often, I come away with the opinion that they aren't relating their experiences as much as they are attempting to appear knowledgeable. I especially believe this is so in relation to resoiling issues because it's something you have to see months or years down the road before it visible and by then the customer has called another cleaner or the initial cleaner has forgotten the product he used last time and chalks it up to a nasty house.
I used Judson's O2 for a couple of years and never noticed anything in the way of excessive soiling that I could pinpoint residue as the cause.
Reactions: Jimmy L
dgardner
Phoenix, AZ
Dan Gardner
I remember a report of the O2 leaving whitish deposits several years ago - it was traced to incorrect (way too strong) dilution.
Idiotā„¢
I can see that happening. The Larry's of the world are so used to 8oz per gallon that they can't force themselves to trust a dilution ratio as low as 2 oz per gallon.
Expecially when 16 would be so much better.
Reactions: GCCLee
GCCLee
East TN
C. Lee
I'm not knocking O2 at all here
You just have to slow down and rinse it good.
Great cleaning ability and an awesome smell so I keep it in the truck for sure.
Another issue I had was the rinse kept growing algae in it so I had to really change how I handled it an how much I had pre mixed.
Simple adjustments by me corrected all these issues fyi
San Francisco, CA
In my experience all acidic, neutral or lightly alkaline rinses will eventually grow algae, if not used for awhile. Definitely not Judson specific.
Reactions: GCCLee
GCCLee
East TN
C. Lee
Glad to finally hear that!
I jus quit mixing as much of it it he bulkhead jug
Jim Williams
Bynum N.C.
Jim Williams
I've used Powermax, Judson O2, Powerburst and Extreme Clean and a few others the last 10 years and they all clean great. Some have a lot of orange in them which makes my sensitive hands dry and crack. For the last few years I have been hooked on Pros choice Extreme clean, mainly because it has less orange peel and cleans great, and for $180 for a 40 lb. bucket it's a great deal. I only use about 3 buckets a year because you don't need much. I also don't use a rinse and have never had a problem with resoiling. Makes the carpets nice and soft and customers love the clean smell. Since you are in Raleigh, swing by Sunbelt and get a bucket.
that's just not true, Marty
and if 2oz pr gal worked on anything but minimal soil, why would you be adding hot sauce to the mix or using Flex for your restaurants?
DOLT
.L.T.A.
Ne
At 2 oz per gallon it works well for furniture.
Didn't like it for carpet because it foamed up too much and was hard to rinse all the way out.
I like extreme clean , cleans great, smells good.
But I recently used some powerburst and wow it cleans great!
But smells BAD.
