Just can't believe it
Albuquerque
Ron lippold
:D :D 24 flow 500 psi just can't understand. Carpet is cleaner dryer so much faster. No streaks dry by the time we leave. You have to try it.
Albuquerque
Ron lippold
750 at the machine 500 when the trigger is keyed oil temp 295 constant temp at the machine 220-230. the wand is heaver and hotter cleaner and better.
Tell me what Im selling other than clean.
RichardnTn
Wow, That's 8 1/2 gpm...what kind of pump are you running....
06 @ 500psi =2.1 gpm X 4= 8.4 gpm
Is the pad wet at that rate...are you checking them occasionally ?
Thanks Richard R
Thanks Richard R
Richard, what makes you think 06 flow = 2.1 gpm?
Put your wand in a bucket and report back your findings.
Brian L
Hollister
Brian L
I don't want to brag or anything but I have two 05's on my 802.
Eat your heart out Lippold.
RichardnTn
Technically 500 psi with an .06 jet is 2.12 gallon per minute.
If you will check Envirospec or Spraying Systems or any other company that supply jets, you will find a jet size/psi/volume chart. Any other result other than this, would suggest that the psi, jet size is in error or I am reading the table wrong...Richard R
Richard, what good is a number on a chart?
Let me know how the bucket test goes.
Thanks.
Very familiar, kinda cracks me up that we see roughly 1/2 the flow that the charts show, just goes to show there are a lot variables.
