Kaivac chemical
jawhit
Joe
Anyone use kaivacs or similar 'touchless' restroom cleaning systems? I'm trying to find out what people use chemical-wise. I'm going to be cleaning large restrooms/locker rooms with these. Should I be using some sort of germicide/quat or just a good all purpose cleaner since this type of system is based on the idea of blessing everything to the floor and then vacuuming to remove soil/germs?
Joe, I haven't used theor chems or equipment. But I should think that any non-corrosive cleaner that drains residue free would be good. We use an enzyme spraydown, followed by whatever is needed. Often rinse with glass cleaner since it doesn't leave spots.
jawhit
Joe
I wasn't referring to their chemicals. Just chemicals in general. So you don't feel some sort of germicide is needed @Old Coastie ?
Jawhit, the multi-enzyme does the crittur-crunching. I'm not sure I can give the brand, since I'm not an advertiser.
Yes, without the enzyme a disinfectant would be needed! However, I urge you to be careful about breathing airborn chemicals. Doing what you describe, I'd suggest a full face respirator until you get to the rinse-down. Harbor Freight sells one for a song. If you smell it, you are breathing it.
All said, it is repeated, cumulative exposure you should prevent. Go knock 'em over and good luck!
