Louis
So I have kohler 22hp that will back fire when I turn it off or let the fuel pmup run to much before I start it.
Ignition is grounded
There is no fuel pump on the valve cover
Fuel prssure is around 5psi
I was told that some older kohlers had a vacuum fuel pump that helped regulate the fuel. This motor was off a old steamway so I have no clue of it's age and the spec # is gone.
I am thinking of putting a switch to turn off the fuel pump before I turn off the key.
Thank You.
Thank You.
